I NEED HELP! Lollipop LG G3 Tmobile SUCKS!!!
Kandyce Wise
I downloaded the Lollipop update... It has been horrible. I LOVED my G3 BEFORE the update. Problems I'm having:
-My volume on videos cuts off 10 secs after the video starts playing. The video will play but no sound. Also most of my notification sounds won't work... It'll make like a little pop sound.
-My phone overheats now
-My phone is glitchy. I have to Swipe more than one to get to a screen or to scoll.
-voice "OK Google" feature hardly ever works until the 4th time I say "Ok Google"
-While typing this my letters keep getting stuck and I have to hit them more than once.
-I can't take screenshots...
-Finally my screen slightly freezes every once in a while.
Help me please...
I'm on AT&T and when we got the update I had glithchy performance until I did a hard reset. Since then I haven't had any problems and she runs smooth, fluid and cool.
I'm on T-Mobile also, but I'm not having any issues like you are. The only thing I have noticed is my signal fluctuates more than it used to and will drop from LTE to 4G.
I did a factory reset after the update. Not sure if that makes a huge difference, but have you tried doing that?
Help me please...
i did the update then reset the phone an it works great no problems
always do the reset after the update
Will backing up the phone with lg backup restore everything including the apps(if you select them)?
I also have a tmobile g3.i did a
Factory reset and have no issues at all.phone is working great and battery performance is actually good
I'm on T-Mobile, did NOT do factory reset and I am not having any problems.
Tdoperfdu
