I need help please!!NO LTE on straight talk
IZZY1340
5
Hello I need some major help I'm sure I can get it here. My problem is I have an Verizon galaxy note 3 but now I have it on straight talk with a brand new at&t sim. Everything works except my LTE it's on something called H+ I don't even know what that is. Can someone help with the apn setting to get LTE someone help thanx alot guys
kentuc794
79
If it is a Verizon phone you will not be able to get LTE on AT&T. Best you could do is root it and unlock band 4 which AT&T uses in limited areas.
Sent from my SAMSUNG-SM-N900A using Tapatalk
kentuc794
79
For me not in my town. When I go to Chicago or St Louis then yes huge Speed difference.
IZZY1340
5
Cool so you think it's a headache to root the phone just because to change that? How difficult of a task would that be?
IAmSixNine
3,157
72
rooting the phone will not change the hardware.
Your phone is physically missing the hardware to work with tmobiles network. It was designed for Verizons network instead.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,109
200
63
If you can find somewhere where att band 4 is deployed then you should be able to get 4glte. Keep in mind that att band 4 deployment is very limited
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
arze176
141
Just out of curiosity
What did you use to Sim unlock the Verizon version.
I have a t-mobile note 3 that I unlocked for straight talks AT&T Sim and I always thought h+ was like a tweaked 4G
But Idk if straight talks Sims even support lte yet. At least the most recent one I got doesn't.
Mine is rooted and has a custom rom and network shows 4glte maybe it supports it or its a placebo effect
Sent from my SM-N9005 using AC Forums mobile app
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,109
200
63
The Verizon Samsung Galaxy Note 3 is factory sim unlocked.
