I need help with my Android phone. It's a new Galaxy S8 note
  • Thread starter Android Central Question
  • Start date
A
When I look at the phone's settings it shows I have no SIM card but there is a SIM card in there? Does this mean there's a problem with the phone or a problem with the SIM card?
hallux
Q&A Team
Jul 7, 2013
12,322
7
38
Are you positive you're looking at the SIM slot and not the Micro-SD slot? If you're positive there is a SIM installed - start by rebooting the device. If that doesn't work - contact your carrier, they should be more than happy to set you up with a replacement SIM card to troubleshoot the issue (or try the one you have in another device). If a new SIM card doesn't fix it or the SIM works in another phone, then you need to file a warranty claim with Samsung (but be sure to be clear about the model, the S8 and Note 8 are different devices).
If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
Dawncompton
