I need help
lethalinjectionj
63
i recently flashed my epic 4g to straight talk. now it has no service. the baseband version under about phone says S:D and unknown under hardware version. anybody know whats going on with this thing?
You'll need to flash a new radio, or the correct radio. Since you're posting in the Epic 4g forum, we'll assume you have the Epic 4g (you know, with the slider keyboard), and maybe flashed using directions and files from the Epic 4g Touch.
Well now I have another problem. I was able to get the right radio on the phone. and I continued to flash my phone. Everything works but the data. I need to put a file onto the phone with efs file explorer. Qpst reads the phone but when I access efs it just shows one folder that says "/" with no plus sign (I can't access the filesystem I'm guessing) I've installed and reinstalled the drivers countless times and restarted my computer (windows xp 32 bit) countless times. I'm dumbfounded.
Sent from my SPH-D700 using Android Central Forums
dextriminator
