• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
I really need urgent help: S6 Edge won't go to sleep, draining battery overnight! How can I fix this?
A
AC Question
This is my first post here. I am new, both to android and my S6 Edge. It is on 5.0.2, rooted, and PLEASE do not tell me to RESET TO FACTORY. I can't really do it because I don't want to, there is a lot of great apps and the internet in my country is very bad.
Idk if it is due to the root itself, but I really need help from professionals. I came back from another forum with no luck. The closest I got was "cocktailbar service", and my S6 Flip cover (they don't have Edge cover so I improvised).
I check every night for wifi, location services and running activities. However, no matter what I do, I fail. It won't go to sleep. When I wake up, it is really warm and it is at 50-60%.
I tried various methods. I have some screenshots you can take a look at.
Please suggest me what I could do ASAP, except update/factory restore. I really need some help and I am desperate... I am sweating and panicking. Did I break it?
Thanks a lot for the support! :')
beagle82
387
Re: I really need urgent help: S6 Edge won't go to sleep, draining battery overnight!
What do your battery stats say. Which app is chomping your battery?
