I think my battery is fried =[
Jeenyus
230
12
Today I charged my TB to 95%, went to church for about 1 hour. When I came home, it was down to 65% on standby. WTF on standby. I am on CM7-1.8 with imosen lean 4.0. It has never been this bad. I also checked the battery usage page in my settings, it only shows display and standby no apps. Do you have any suggestions
Depending on your preferences...
OEM
NEW OEM HTC Thunderbolt Battery 1400mah BD42100 BTR6400 | eBay
Replacement 1700 mAh for OEM with external charger
Amazon.com: HTC VERIZON THUNDERBOLT 4G LTE 2x1700mAh Battery better than OEM (35H00142-07M) + Wall Travel Dock USB Charger PD42100 BY CHICHITEC ONLY: Cell Phones & Accessories
VZW Extended - last I heard VZW was selling it for around $30
VZW Extended with cover
-Frank
Reactions: Jeenyus
So my battery goes from 95% to 38% on standby with 4G (I switched to 3G before screenshot) in about 2.5 hours.
Your idle current is too high. You should be screen off idling at 34-56mA; it seems that you're at 150mA currently.
So that explains why your battery is draining 3x as fast. You have a rogue process, bad signal, app running constantly, or the mystery drain ( I used to get this a lot of Froyo, for no reason my phone would start pulling a lot of current. It's fixed now but I don't know if it is due to me never using 4G now or running CM7, updated radio, and other ROMs)
I don't recommend the batteries from CHICHITEC they aren't authentic HTC batteries. I used them on my Incredible and they didn't last very long.
I thought they weren't very good. Just wasting money............
SOULUTION: sadly to say I've found the solution. It's he latest version of widgetlocker from the market that's draining my battery. After uninstalling it my battery life is great.
Reactions: natehoy
Cool, glad you were able to resolve the issue. But, it really gets me thinking about how many other problems may be caused by apps? I say that because I highly limit what apps are installed to reduce complexity (these things are already complex enough) and I've had no problem with the operation of this phone while running it completely stock with only about a dozen apps in total. This is very similar to my experience working in the IT field for almost 15 years now as I've seen many a problem caused by the installation of various software. That's why I'm convinced by and try to live the K.I.S.S. principle as it has proven VERY effective in reducing problems. :)
chzahid600
