I think my /data & /system is too small
1999ws9
Active member
Jan 7, 2012
30
I'm rooted and I have a 32gb card and yet I am out of space to install any more apps and can't update the stock software that came with the phone.
My Link2SD shows this:
/data Total: 161MB Used: 143MB Free: 17.81MB
/mnt/sdcard Total 28.64GB Used 1.58GB Free: 27.05GB
/data/sdext2 Total: 0.89GB Used: 65.76MB Free 850MB
/system Total: 161MB Used: 159MB Free: 1.93MB
/cache Total: 93.76MB Used: 356KB Free: 93.41MB
I tried to use MiniTool Partition Wizard thinking I could enlarge the partition but all I see is one primary Fat32 on the sd card.
How can I increase the size of the partition that I cannot see? :confused:
I don't think your on data is on ur sd card.
Adb shell or emulator
Su
#cat proc/partitions to see what's where.
Also are your partitions systems correct?
Refer to firehaks pdf.
Also you would need sd-ext on kernel. (I'm working on adding it to dmrlook s kernels)
Ill be in irc
Sent from my SPH-M580BST using Tapatalk 2
Twousay
