I want to ask about battery drainage of my s6 edge
Dr Asaad
Actually ive not its original charger . I charged it with 2 3 chargers but it gives me poor battery time . Then i bought original charger of hp with 3amp . It gives me 3 hours continuous usage with remaining 56% battery . Then i slept and when i woke up its standby consuming battery with wifi on is 16% which means it was on 40% . I want to ask that if it is normal ??
Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/ge...ide-how-post-screenshots-android-central.html
You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
Edie Raleigh
