ICS Face Unlock Problem
TomD
130
I set face unlock and it works OK.
My problem is I also set the pattern unlock. I did not expect that they both would activate at the same time. Now if I want to change from face unlock to something else it asks me for the pattern, which I did not record.
Could someone help me with my duh moment?
How did you set facelock with out setting a pin or pattern lock??? I think what you did was setup facelock, and set the patternlock and forgot it.
Here is a screenshot of the very next screen that comes up after you let the phone take the picture of your face...
And no matter how many times I tried to skip it I couldn't.
But here's how you can fix it.... I think.
Unlock the phone using facelock, and see if you can disable it in settings. Then if you still want to use it, just re enable it. But... I may/most likely ask you to input pattern...
I remembering reading somewhere that if you enter the pattern wrong an X amount of times you can reset it.
Sent From My Galaxy10.1 Class Starship....
Click to view quoted image
I disabled Face Lock. Now I'm stuck. I get a blank black space where the face unlock was and then the pattern comes up.
I have not been able to get past the pattern by making enough errors. It does give you a 30 sec wait after 5 incorrect inputs.
I may need to apply the ICS update again, if I can't get past the lock screen.
It gave me a chance to login to my gmail account and took off the screen lock.
Learn something every day.
Whew
Whew
That's what I couldn't remember.... The email thingy... Nice, glad I could help out.
