I am very grateful for this leak. It is fun to play with but really isn't dd material imo. I've read all the threads about it and there are all sorts of problems. At the very least a better kernel is needed. This kernel runs full power even when phone is sleeping.
Jesters Liquid 2.6 ICS is good enough for DD in my opinion. It's AOSP, no lag and good battery life. I also get pretty consistent 4G speeds (the icon always shows 1x though, but that's a known issue).
What kind of speeds (Mbps) are you getting with it? Thanks.
I was getting 4g speeds with it,any others were as well. Go to rootzwiki or xda where ever it is and check the tread,: its a nice ROM.
Edit * Here is a screen shot shot from it.
Sent from my ADR6400L using Tapatalk 2
I think kernel and radio are included. Check OP
Sent from my ADR6400 using Android Central Forums
I can also confirm ICS Leak is nasty on battery life. It's also laggier than laggy.
Strongly recommend Liquid ICS, its just incredible. It has some faults, including radio issues like it reports 1x when its really 3G, but imho it's the best ROM for this phone period. Not even HTC could work something up that would even stand up to how good this ROM is.
FYI for those with battery concerns, I'm going on 1d 18h and I'm at 60% battery left, and I had the screen on for 2h 15m so far. God like.
