Ideas on Wireless Charger
bhameyedoc
98
The Droid MAXX is my first phone with wireless charging. I'd like to know what chargers people are using, and if you recommend them.
Thanks!
Am I correct that you need to take your phone out of the case in order to use wireless charging?
I have the Tylt Vu charger and I really like it a lot. The phone does not get too hot, you can place the phone anywhere and in any position and it works, plus the phone is displayed at a 45 degree angle making viewing very easy while charging. And no, you don't have to remove the case. Mine charges just fine with the case on. I have the Griffin Reveal case that has a back.
I got a couple of the Nokia chargers. No problems so far. I am charging my phone with a bumper on it and no excessive heating.
ghost 100 is good and fast actually.. just have to make sure phone temp is low before putting in on.. 83 usually stays below 100
Posted via The Maxx
e1nric
