im almost done building my rom but i need to change build # how?
Cameron816
13
i need some help quick thanks people who help get it first thanks some features in this rom includes faves from the mytouch 4g plus mytouch music etc its gb2.3.3
Re: im almost done building my rom but i need to change build # h
Isn't the build info found in /system/build.prop?
Go to "/system/build.prop" and edit the "ro.build.display.id=" line. Make sure to use Notepad++ editor or similar, as regular text editors may add extra formatting when you save the file.
how do i make it say CamROM in the about phone menu>?
ragnarokx was more specific than I was, but that line should do it. Reboot will likely be needed after editting.
anyone know how to change what it says when you pull down the notification area on your phone? mine says "Sprint" but when i was running sROM it said sROM, now im running gROM and i want it to say gROM, or whatever i decide to change it to say.
Here are a couple of methods to do it:
http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/95962-how-change-your-carrier-name-now-scrolling.html
If you are building from thekraven's source, you can cherry-pick the following commits to give an option to change the custom carrier label via the CyanogenMod settings menu.
Code:
git fetch http://review.cyanogenmod.com/p/CyanogenMod/android_frameworks_base refs/changes/14/7314/2 && git cherry-pick FETCH_HEAD
git fetch http://review.cyanogenmod.com/p/CyanogenMod/android_packages_apps_CMParts refs/changes/13/7313/3 && git cherry-pick FETCH_HEAD
