Impossible to add fingerprint HELP
sbrisu
4
Hi everybody,
My Samsung S6 "Add fingerprint" function freeze and I can't add any fingerprint... the white screen with instruction remains "Place finger on Home key, lift it off, etc" but nothing happens when I put my finger on & off.
The already installed fingerprint that I set at the beginning works fine, so I presume is an Android bug... anyone else experienced this?
Thanks,
F
Thanks dumpedduce, yes I tried the reboot and also the wipe system cache, and notyhing change... there is the possibility to install single system apps, like Fingerprint alone?
Thank you so much, how can I install an .apk file and where did you find it?
I am completely new to Android...:)
Download the apk. Click on it through the file Explorer and it should automatically pop up asking if you want to install. I got the apk from my phone by using an apk extractor.
chandrest
