• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
In car audio solution
Mark Calica
Hey guys, just got my one M8 and so far I'm loving it. I just have one inquiry about how to make my phone play through my in car audio. I have an iPod adapter that worked with my old phone and I thought it would work with the M8. Is it because the micro USB doesn't support audio play back?. Is there any work around this?. I also need a file management system cause android file transfer does not recognize my phone. BTW I'm using a MAC mini. I also added a 16gb micro SD. Thanks guys...
BadgerVadge907
46
do you have an aftermarket head unit? or oem? i hate that everything works for ipods. if that dont work you probably have to use the auxiliary or a usb stick.
BadgerVadge907
46
also i didnt see the part where you have a mac...u need usb drivers or else manually load in a card reader, or wifi transfer app. theres alot of ways
B0WIE
1,025
If you can't stream bluetooth music, look into the the HTC "Stereo Clip".
sitlet
176
If you have an aux in, you can get a 3.5mm cable and connect to the headphone port. Otherwise, you can use a usb cable, just put the phone in disk drive mode, and the unit should see the phone as a flash drive, and you should be able to access the files.
fatboy97
4,820
891
Personally, I just go Bluetooth all the time.... but if you don't have that options the next best is to use the Aux In and a cable. The cable is what I had to use on my last car, but I really like my new car with the Bluetooth streaming.
techitrucker
270
Alpine and Pioneer both make sub $200 stereos head units with Bluetooth that work great with this phone. Short of that about the only thing that is going to work with that obviously older factory unit is a cassette adaptor or FM modulator. If you do any sort of traveling skip the FM modulator. They're crappy enough to begin with without adding a variable like travel between cities. I have the Alpibe which is $199 @ Best Buy. That one is a little high because it includes XM/Sirius. The Pioneer is available at most stereo shops for $149. I never understood why car manufacturers would do something as stupid as put in a propriety jack without at least a simple auxillary jack.
Armadillo, the other white meat.
buckifvr
872
18
Yeah, I agree I think a new head unit is the way to go.
B0WIE
1,025
Using a USB cable.... which means you usually have to have a modern/newer unit that has a USB port as input.
Thanks, but is there an actual setting on the phone, or is it just a reference to plugging it in via USB? My car is new and has USB, I just never heard of putting a phone into a disc drive mode and wanted to know if that was a setting on the M8.
Also, to the OP, instead of $200 on a head unit, look into the $27 device I mentioned earlier. It allows you to stream bluetooth music to your Aux input.
TJGEsq
112
I'll have to emphatically disagree with you. Perhaps you meant to say that FM transmitters are crappy, which I agree with. FM modulators are fantastic, and it doesn't matter where you travel.
Sent from my HTC One_M8 using AC Forums mobile app
fatboy97
4,820
891
I don't believe it is something you need to set, BUT I believe you do need to enable "Developer options" by going into Settings > About > Software information > More > tap the build number until it says you have enabled developer options.
phoneaddict78
105
If you wanna keep your factory stereo I would put in an fm modulator so you can add an auxiliary jack. Then you can plug in a bluetooth receiver to the auxiliary jack and stream through bluetooth if you wanted too.
Sent from my LG-LS980 using AC Forums mobile app
