Incredibly acting up x_x help?
DragonicTunes
I have a Droid incredible. All of a sudden, my lock/power button is acting crazy. Sometimes it works, sometimes it doesn't, sometimes it pops open the power/airplane/restart screen over and over and sometimes it doesn't, and sometimes I can't even turn my screen on. I pulled my phone apart already as I don't have a warranty and the hardware seems perfectly fine, not jammed or stuck. What's up? It also occasionally starts playing a song from my SD card on it's own that isn't running through any of my music playing apps and has no volume control. This started the day after my power button issue. It is currently running Android 2.3.4.
Edit: Also, my phone won't stay off if the battery is in it at all, acts up while charging, and sometimes when the lock button works, the screen will still come right back on. Even if I tell the phone to shut down, it will immediately come back on after shutting down.
Edit: Apparently the song it was playing was coming from my email, my phone mysteriously switched my notification tone to it, I switched it back and we'll see if it happens again. Can someone please help?
I have never heard of those kinds of issues before. My suggestion is after you have searched this website, you might need to get it looked at by a technician. It sounds like a short somewhere. Check all your options before the last resort... a factory reset. Maybe there are some posts in this forum that I haven't seen that may help more than me. How long does this happen on average?
Anwar
