Infuse WiFi Problem
acealex123
I've had my Infuse for about a year and I love it. There is only one problem that really frustrates me. The WiFi connection at home. I tried to fix it when I first got the phone, but I just gave up. Now I would like to try again.
Basically the problem is that my Infuse will show me that I am connected to my home WiFi (the router is a Linksys befw11s4). But, when I try to connect to the internet or any other apps that require connection to the internet, I messages like "failed data connectivity" or "connection timed out" and stuff like that. My laptop and XBox connect to the internet perfectly. If i go to Starbucks or any other place that has public WiFi, it works just fine. If installed some WiFi fixer apps, but those haven't done much. Could someone please help me out?
I had the indentical problem. WiFi worked everywhere but home. I spent a ton of time w/ ATT, Samsung trying to figure out the problem. Eventually i discovered that somehow the phone and the router had forgoten that each other existed. It turns out all I had to do was go to settings, WPS button connection and then the "press WPS on your WiFi access point". Once I did that everything was fine.
Reactions: Cranky
ChrisAndroid
