Inspire problems and issues
robthesixthree
119
3
Can anyone direct me to any posts regarding hardware issues with this phone? Screen not rotating in particular. Thanks
Sent from my Desire HD using Android Central Forums
Is it enabled in the settings?? 0.0 and the home screen do sent rotate just applications and the browser
Yeah its enabled. Nothing will landscape unless the app is native landscape. Browser won't rotate at all unless I go into the settings and manually do it. Every time I try to calibrate it says calibration cancelled. Auto rotate will not work. It's annoying as Hell.
No one else having this issue ? I find it hard to believe! My phone won't auto rotate, the captive buttons no longer light up, and the phone resets itself if I take a picture with the flash. No one else having any of these problems ?
Oh bro I hate to say it but the sensors prolly screwed up try this give it a nice thump I don't mean beat the hell out of it but turn it and let it hit your hand a little if it don't rotate then your sensors screwed up get a sensor app off the play store see what happens 0.0
Try thearket for a force landscape app I know there is one to stop it from landscaping...
Sent from my ATT Inspire 4g
boone
