Installed Legendary Rom - Notification Light Not Working
pugsly8422
7
Well, as the title says (after many hours) I managed to install (aka flash?) the Legendary Rom on my phone. At first I was having problems with it, but the kinks seem to have worked themselves out. At the moment, the only problem I seem to still be having is in regards to the notification light. It no longer flashes when I have texts/emails/missed calls, nor does it turn red while charging, or blue when it is fully charged. Is there anything I can do to enable this?
Thanks
Hadn't noticed that. I would imagine that its one of the mods, with some setting deep in the ROM that we haven't found yet...
Reactions: pugsly8422
Sorry to hear Pugsly but I'm running Legendary ROM myself and my notification light works for me. Did you do a clean install or just flashed without wiping everything clean?
I actually followed qbking's youtube video while doing the install, and he had said to wipe everything, so that's what I did. I think it may be the charger because it's been acting up (I ordered a new one over a week ago, still waiting!) by only charging when the phone is laying flat on it's back, and whenever I lay the phone down after connecting it, it vibrates very loudly. So maybe they're related. Unfortunately I don't know anyone else with an Epic, so I can't test that out until I receive my new charger.
It's good to hear that it's not just part of the ROM, I really like (and appreciate) the notification lights. Hopefully it's just the charger, or a bad install, at least those things can be fixed.
Thanks for your input Groove, you've given me hope.
Thanks
First, I had a perfect flash (went from Legendary RC 2.0 to v2.1).........everything is running as good or better than this device has ever run, since flashing this over a week ago.
Sometimes a bad download or else a bad flash can create erratic bahaviour on your device.
.............fyi: after much lobbying (by users/testers) the devs decided to include a mod in Legendary_Release Candidate 2.1 that is a "no beep / no screen on" when the battery has reached 100% charge.......this is so that the beep will not sound off in the middle of the night + waken you up.
OTHERWISE, other than charging, you should be getting notifications, I know that I am...........Q: what version are you running? prior to flashing, did you clear cache + dalvik x 3? were you on a prior firmware before this flash?..............you can always reflash the current version of your Legendary ROM (right over itself), and then, from recovery > restore ONLY your data (from your most recent Legendary nandroid/backup over the new flash).............hope this helps.
Anytime buddy! Hope you get it resolved!
gerryreed39
