Installing AC Sideloader Wonder Machine on F drive
Hello and welcome to the android forums my friend. Which device are you using? Pretty much about 90-95% of android devices out there will allow you to install third party applications so you would not need to use the ACSWM.
Thanks for the welcome. I have a Motorola A855. My carrier doesn't provide data service so I need to install apps from my pc. I am running Froyo. Any suggestions?
That makes a little more sense. But your phone should be able to connect to wifi.
It should. How would that help?
Because with connecting to wifi then you should be able to get on the internet. I would go then check the settings>applications> and see if you have a box area to check for unknown sources. If you do, then you do not need the SWM
