Invisibile Shield installation + Water Damage Indicator = Disaster
kellte2
73
After installing my invisible shield this morning, I turned the device over to replace the batter and low and behold the darn thing is a slightly deeper pink in the corner. The indicator itself isn't totally shot, but just the corner.
Anything I can/should do, or am I just SOL?
You can replace the battery. If the indicator in the phone isn't tripped you will be fine.
I was putting an invisible shield on the back panel first to remember how to do it properly. when i went to apply the screen shield, i had the back panel off, so it was the phone one that got tripped - down in the corner...
It isn't red though, just a slightly darker pink in the bottom right corner (must have only been a drop). On top of that, you can still see all the Xs clearly.
It should be fine. Although it depends on how the person inspecting the phone decides to interpret it.
Water damage indicator?!?!?! WHAAAT?!!?
The phone actually has something that will indicate that it got a drop of water around the edges??
I was just getting ready to put my BodyGuardz shield on - now I'm second guessing!
Any recommendations then when apply a screen shield to avoid 'triggering' these things?
Well it sounds like he had the back off the phone, a little splash would trigger the sensor. best to keep the back cover on, to protect the inners.
Almost all cell phones have water damage indicators these days, so when you drop your phone in the toilet you can't just dry it out and then go in to claim it "just died" on you.
But the liquid application is exactly the reason I'd never install an InvisibleShield on my phone. I don't need to be squeegy-ing water into every port on the device. I'll get a self-adhesive protector and replace it when I need to. Worked great on my last phone for 1.5 years.
Interesting... I think when I installed the last one on my Pre I took the battery out but then put the cover back on. Seeing as they're installing these at the Sprint stores and BB I guess there must be a way to do it w/o triggering anything. Hopefully the cover is water tight enough to allow for a little mist on the outside. Heck, it was raining when we left the Sprint store today so it got a drop or two there! :D
Thanks for the info!
There's the suggestion of q-tip and bleach. I don't want to make it worse, though
or you could go to best buy and ge tthe black tie protection than it doesn't matter if you ever want a new one...
sa1234
