Is anyone using light flow with success
elvis1935
182
4
I can't. Seem to use the led with it cause it just stays green. and now all my folders when I open them say folder is open and then closed. I hope someone will have a idea of what I can do to fix it and the led.
If you look in the known issues it list all the issues with the GSIII. I downloaded it and played with it but just disabled it till they work out some of the issues.
Adamsapple
