Over time wear and tear will kill the back
Spare battery is a necessity with the V10 as the battery life is relatively short. But with a spare battery and cradle, no phone compares.
Oh it will huh? So you killed your back already with wear and tear?
Depends on how one treats the V10's back. Removing it and replacing it over and over will eventually have the plastic give and introduce cracks near the areas where the back clips onto the phone. Had this happen with every phone I had or had experience with that has a removable back (GS2, S3, S4, S5, G3, etc.).
On the bright side, removable backs for the V10 aren't expensive and won't wear out as fast due to the silicon-esque layer over the actual plastic of the door.
Posted via an LG V10
My gf still has an S3 and changes the battery every day. She has 3 spares all on their way out. No cracks or other problems. I've never had a problem with removable back. I'm trying to get her to change phones as you might guess.
With my V10 like I mentioned in a different thread, battery is very good on MM. I no longer need to swap batteries.
I change batteries at least once a day since I got the phone back in December. I have not had a problem with the back yet.
Im thinking of buying a spare battery for my friend’s LG V10. Is it easy to swap battery?
One thing I'd like to tell you regarding battery swapping. You need to wait a few seconds after removing the old battery and before putting in the new one. If you go too fast, the phone will not recognize the battery change, and when you turn it back on, the battery percentage will still show low. I have seen this several times, as I swap batteries every day instead of plugging the cord into my phone all night.
Cheers.
Good advice... thanks!! We need to unplug the USB cord too... correct?
For those interested, the special is still going on at LG's website. Charging case and battery when ordering both, they are just 10 bucks a piece.
