is it possible to have more home screens?
McNooberson
10
Like the iPhone ya know? I have a lot of Apps and it would be cool if I could see them in home screens rather than the pulldown menu. Is there an application for that maybe?
There's apps in the Market that you can DL to make that happen.
Open Home (paid and lite versions) is one of them.
No lag that I've noticed with DxTop. However, I'm not using any theme. Basically just using the stock theme but with the added functionality of dxtop (the 4 panes, swipes to get to the panes, customizable app drawer, etc)
I have both Open Home and dxtop loaded. I kind of like Open Home just a bit more because it has seven screens available and just a more natural movement to it. Left and Right movement. dxTop is a good product which has four screens available but works in a box motion. So right once then up once then left then down. I always get confused which one I'm on. But dxTop has drawers so it's a toss up.
Play with both then return the one you don't like. That's what is great about the app store.
Another one coming out but not ready for prime time yet is Sweeter Home. Take a look at it and it will blow you away. I downloaded it but it is not ready yet. Still lots of bugs.
And to answer Mclarryjr there is not lag that I have noticed including when I switch between home screens. Very fast.
are there like free themes? ive been looking and everything costs money....are there any free themes out there?
Panda only has the stock 3 right now. More are coming from what I hear.
Panda for Droid has MORE then 3 screens, you can create as many as u like by just dragging a widget or icon to the left or right and the screen will be created. I CURRENTLY have 5 and can add a sixth.
Panda for the Droid is free in the android market, just search panda home. It is quick and no lag. The only bug I have seen is sometimes when long pressing an icon it brings you back to the home screen. This is very very tolerable and should be resolved soon since its a work in progress. It only happens a couple times a day.
I have GDE homescreen on my Droid. Up to 7 different homescreens, different transitions, zero lag, just awesome. I love it on my Droid.
itsnotmac
