Is it possible to re root my Samsung Galaxy note 3 and if so how?
Johnyboy169
I currently have a Samsung note 3 running Android version 5.0. It has previously been rooted before and then unrooted (because i accidentally bricked it), my question is that. Can i now re root my phone.
By the way I've tripped knox...
Johnyboy169
Hi Rukbat, thanks for replying. So are you saying that my device can be re rooted? (it is not rooted any more)
I am from the UK and my phones carrier is EE
Build number: N005XXUGBOA1
Rukbat
Retired Moderator
Feb 12, 2012
44,533
19
If you have a root method for the 5.0 ROM for that model S3, sure. (Rooting is, at its basics, trivial. You put a file named su in the /system/bin folder. But to do that you have to be rooted, so Catch 22. People who come up with root methods find little bugs that allow them to gain root access just long enough to copy one file, and that's all it takes. But then the manufacturer or Google patches that bug, and someone has to find one for the next update.)
janidbest
