Is the samsung6 edge worth it? ( over regular s6)
Compare the features. Do you need the "edge" features? If not, the regular s6 is fine. I'd choose it if I didn't have an edge already.
Do it all over again, I would of gone with the S6 regular or waited for the newer samsung devices. The screen is really pretty so just hold both in your hand and see how it feels to make the call.
I have the edge but TBH the edge options are quite useless right now. I'd probably buy it again anyway but you should do it only if you think the appearance worth the extra money.
I've had my S6 edge from day one, and I would buy it again.
@Rebellz is right, the edge options are quite useless, I never use them.
However, the screen is beautiful to look at. If you are worried about glare, I would buy a matte screen protector, cuts down on the glare.
I love my edge. I've had it since release. I enjoy using the edge features like night clock but I could certainly get by without them. I just liked the unique design and still do. I have nothing negative to say about the edge portion of the phone.
A little late to this party, but I LOVE the edge. I've seen Note 5 and Edge+, but those are a bit too big for my taste.
Put it next to an iPhone 6s and you will see that the curved screen really looks awesome, it's bigger screen for the same phone size, and the image quality is better too. The curved screen is not fragile at all. Hold it in your hand for a while and you will see what I mean.
EDIT: I know you asked about the regular S6 in comparison. All I can say is that the S6 looks not very different from the other phones, but a die-hard iPhone fangirl did comment on how the Edge looks sooo much nicer than her iPhone and she was actually tempted to consider switching. (She's very much into how fashionable things look.) :P
Good luck deciding! :)
Thank you. I had the S5 before. Finally went into the store to actually get hands on with both and the edge was reallt nice to look at..and felt comfortable. I loved my S5...and while the S6 pretty much looks the same..with the acceptation of the glass back...I really liked that edge look. Thank you for your input. :)
Tomc
