Is there a huge difference in speed between 2.4A and a 3A for Type-C fast charging purposes?
chris9000
17
AUKEY 16000mAh Portable Charger with Quick Charge 2.0 & USB-C Cable
Tronsmart Presto 12000mAh USB Type-C External Battery Power Bank with Quick Charge 3.0
Deciding between these 2 power banks for my 6P. The Tronsmart bank seems to fare better on fakespot for having a lower likelihood of fake reviews and seems to support 3A/5V charging. The Aukey one has a higher capacity, but it's rated as supporting 2.4A/5V charging.
My concern is being able to run Youtube, maybe play Pokemon simultaneously without worrying about the phone draining the battery/bank faster than it can be charged.
Any thoughts? Is there a huge difference between 2.4A vs 3A? Will the Aukey's 2.4A charging be fast enough?
The Tronsmart is the only one with native USB-C support. The Aukey just gives you a micro to C cable. As for charging performance, you're obviously going to get a quicker charge from the native C brick. But that 2.4A rating is the best-case current and you may not be able to see that on your 6P... since it is not QC compliant (QC isn't compatible with the USB-C Power Delivery spec). As for AiPower, no idea what they is, what it needs to work and if it'd even function properly over a micro-C adapter cable.
I'd stick to the native USB-C charger.
Thanks for the explanation, guess I'll be sticking with the Trons.
dkpiper
