Is there a way to set a timeout for requiring a PIN for unlocking the Nexus 7?
douglerner
432
On my iPhone and iPad I use a PIN to unlock the devices because I don't have to use it every single time, which would get really old. I have it set to 1 hour, which seems reasonable. So if I don't use my iPad for an hour then I have to enter the PIN again. That seems secure enough to me.
On my Nexus 7 the PIN security option doesn't seem to have a timeout setting. Is there a way of having one? Or is "use the PIN every single time you unlock or don't use a PIN at all?"
Thanks,
doug
Do you have more than one user set up on the tablet?
Nexus. Through spacetime.
I see. The timeout options don't reveal themselves until after you change to PIN.
It only allows settings up to 30 minutes, but I guess that's okay.
Thanks!
aravrajak
