Is there an easy fool proof way to convert my sd card to adaptable internal storage on a S7 Edge?
  • Start date Start date
I don't believe there's an app that can do it without root. It's best to just follow the instructions in some of the articles that have been posted. I enabled adoptable storage and while it's cool, the phone stops displaying storage space correctly, and burst mode no longer works in the camera. If you can put up with those things though, go for it
i just use touchwiz setting to move to sd... But most cant be move to sd card... Lol...
What would be the advantage to doing this as opposed to just transferring apps the Samsung way?
In a lot of instances, this moves very little from internal storage but adoptive storage allows the ext SD card to be treated as internal storage which is fine unless the card goes bad or gets stolen.
sportzfyapp
