Is there any way to get better sound on my n7 ?
troyyank
is there anything i can do to make the n7 louder ? its low even with ear buds n head phones , with all volumes maxed. or is the n7 just weak in sound? any apps the would beef it up some, its very low with its own speakers and headphones as well :(
There are apps like "Music Volume EQ" that can boost the volume. It should already be plenty loud through ear buds unless they are some high end ear buds that take a lot of power to drive. Check the music volume in settings/sound/volumes, it might be set low. Mine came set to max.
Reactions: troyyank
You might have something wrong hardware wise because this Nexus 7 is alot louder than my Transformer.
Reactions: troyyank
r3dpuk3
