Issue in opening samsung s6 edge+ theme
Nov 13, 2015
3
Hello there. I want to know. How can i fix my S6 edge+ theme? Because somehow it suddenly cannot browse the Theme.. I have clicked it again and again and i still could not open the theme. Now i cannot download any new theme. Is there any way for me to fix this?
Sounds like u have a software glitch and need to do a factory reset.
Posted via my SM-G928F
What is factory reset? Do you mean i have to reset my phone? Everything? Is that what you mean?
Yes. Usually software glitches like that don't go away until u reset ur phone. Back everything up and wipe it in settings. It should be fine then.
Try a simple restart first. Hold the power button on the right-hand side for about 2 seconds and then select restart. It will power-cycle your phone. It's worth a shot first to see if things start working again before you do a wipe/re-install.
Thank you for yr suggestion and i did restart my phone. But it seems that there is nothing change because when i tried to click the theme, still cannot browse. So i guess i have to reset eveything back then....?
Yeah, it sounds like a factory reset is in order then. I forget what buttons you press to do that, but someone on here will remember and will chime in. Best of luck and make sure you back-up your photos, contacts, etc. beforehand.
Settings >backup and reset
tripalh
