Issue switching from Wifi to 3G
rjmlakota
24
Ever since switching to GB I've been having a issue with switching from Wifi back to 3G.
When having Wifi turned on and then turning it off on my DroidX, it will not switch to back to 3G. The only way I can get the 3G connection back is to turn the phone off then on again.
Has anyone else been experiencing this issue every since updating to GB?
Does anyone have a fix for this?
Thanks,
RJ
Nope, no such problem here. When you do get 3G back, what's your indicated signal strength?
Yes same problem here. I tried just turning the radio on and off again but only a reboot seems to work.
The only way I can get the 3G signal back is to power cycle the Driod X.
When the above occurs, I have 3 bars showing but no 3G icon.
I dunno then, call Verizon? I go between WiFi and 3G all the time with no problems.
I'll be going to Verizon after work to review the issue with the tech there.
mlbdude: I will keep you posted as to what they say.
gordol: Thanks for the help.
RJ
shahindaosama22
