Issue with light leak , will I get an exchange?
adamblaby18
7
Basically I have 2 reasonably big white marks bang in the middle of the screen. I bought it from bestbuy in the UK will they exchange it do you know ?
Thanks.
Sent from my Transformer TF101 using Tapatalk
Some light bleeding is normal with back lit displays, i you feel its more than it should be you can exchange it but I would bet your next unit will have some bleeding also.
I returned one to Best Buy with no problems at all for light bleed. The next one I received has been fine and dandy.
This right in the middle of the screen and a huge distraction whilst watching films etc
I would return it.
It is your money, and one should expect better than that.
chadreich82
