Issue with S Health and ANT+ Garmin Heart Rate Monitor
  • Start date Start date
A
AC Question
Hi all,
I have a Samsung S4 and recently bought a Garmin Heart Rate Monitor with ANT+. When using the S Health app to track my exercise, I can see that the phone and HRM are paired, and the S Health app is registering my heart rate AND gives me a chart of my heart rate during the period of exercise, but it doesn't calculate my calories burnt properly. I cycled home for 40 mins the other day with an average heart rate of 178bpm and it said that I only burnt 150kcals (is this calories, not sure why the extra 'k' as it's certainly not for kilocalories!), and when on the treadmill today for 30 mins it said I burnt no kcals!
I'm hoping I missed something really basic in the setup here, so any advice would be appreciated.
Thanks,
Jade
Hi
I've been struggling with this on my NOTE4 and may have a suggestion. S Health lists the compatible hrm straps and then lets you "Register" your choice. I have a Garmin ANT+ HRM1G. I've already set myself up in S Health so the setup wizard was not active. I had to find the appropriate screens manually as follows:
1) Open S Health
2) Select the steps monitoring screen. My screen has "Jack" (me) in the upper left , "More" in the upper right, and "Be more active" as a header. It displays the number of steps today etc.
3) Select "More" (displays (Manage Items, Partner Apps, Accessories, & Settings)
4) Select "Accessories" (displays Registered accessories and lists View More at the bottom of the list.) I had to View More to find my Garmin
5)Select your ANT+ HRM (I wore mine but I'm not sure if it is necessary)
6) When you select a compatible HRM, "Register" will display in the top right hand (in green)
7) Select Register and the devices will pair
Good Luck
I still am having problems getting my S Health to read from my Garmin Heart Rate Monitor... I paired it up, but it is not reading...How do I get it to stop using the phone sensor and read the Garmin HRM?
Anyone managed to make this work ? I have the same issue paiting with a Timex 2.4 GHz HR band. It appears when scanned and registers, but I get no HR reading within S Health app. I checked my S4 is receiving a signal from the HR monitor since Strava gets a HR reading.
Also tried uninstalling the latest update and going back to the original version of S Health and it paired with the HR monitor and gave a reading, so it seems the issue is with the new S Health update.
Hi,
I was also trying to connect my HRM with S Health and was confused why isn't it reading my heart rate even though Garmin HRM is registered.
Well the reason for this was I haven't started any activity on my S Health. Once I start an activity it starts registering my heart rate. It's not like your other HRM that constantly tracks your heart rate for example vivo or gear.
Hope this helps
Marioprattes
