issues with Android Auto with Note 8
lhoffstadt
Hi everyone,
I wanted to shared the experience that I'm having with Android Auto and my Note 8, usually it does not work when trying to connect on the first try, it gives me an error on Screen that is Unable to connect with Android Auto and also on my phone it appears the option that I want to enable the access to my files (I always say YES)
I have noticed that usually after I reboot the phone it does work without issues. At first I thought it might be a faulty cable, but no, I changed the cable and using the original USB C cable that came with the phone.
Has anyone else experience this issue?
Also, when Google Maps work on Android A. is there a way to put the speed limits on the map?
Thanks so much and stay safe.
hi ,i keep on having this issue ,i have had it with a few different samsungs ,9 note,10 and now the 21 ,i can plug it in and no matter what i try it fails to connect ,even after uninstalling and reinstalling the AA app and trying diff leads ,and yes as you say a lot of the time a restart will solve it ,but TBH that's only the half of problems i am having ,google assistant keeps piping up for no reason i now tell it to [Mod redacted language] she po;ite;y replies .oh i am sorry i upset you
alejandro109322
