- Oct 30, 2009
- 914
- 27
- 0
I am definitely seeing issues with wifi. For no apparent reason it will just cut out. I thought I was imagining it until I set up a Smart Action for home that dims the screen. Periodically while setting thing up, etc., the screen would brighten and when I would look at the wifi icon it would have zero bars and be white. It would immediately try to reconnect, but this is definitely not normal behavior.
I'm also only getting a 1x signal at work. I'm usually good for 4G here, though low. And if not 4G, then 3G.
Is anyone else seeing issues like I'm describing, or did I get a dud?
