Issues
cdemot02
169
4
18
Anyone having the following issues...
My Android auto cuts in and out. No issues on same cable on my wife's phone. The last two days the Bluetooth won't connect with Android auto, and I have to restart the phone to make it work.
My screen will fast flicker then shut it's self off. I have to wait then it'll work again, but I restart the phone to clear everything.
Constant crashing with Google sheets using chrome.
I have a Pixel 6 Pro. I have none of those issues.
I don't use Android Auto, but I have noticed the Bluetooth cuts in and out on my Pixel Buds much more frequently than before the January update. Looking for some relief with the February update.
What does the Google Sheets on Chrome crash look like? Have you already tried clearing the Chrome app cache/data?
I bet that answer is SUPER helpful to the OP! :confused:
To the OP, are you on the latest security update?
How long have you had your phone and did this happen from day one or just after an update if you've gotten one?
Have you tried using the Google Sheets app vs. in Chrome and if so, does the issue still exist?
I've had it since day 1. Chrome crash is just a system not responding error. Everything up to date.
I'm starting to believe the Android auto is a bad port. No problems charging all with the same brand of cables. Plus my wife's 5 works fine with the cables.
It actually is very helpful. If all users have the same problem it points to a system wide / OS issue, as in a bug with Android 12, or a specific app, etc. If other users with the same model phone don't have the same issue that's helpful in troubleshooting the problem in a specific phone.
opegamani
