It occasionally has loud "ringing" noises for up to minutes
  • Thread starter Android Central Question
  • Start date
A
This started within the last months and it is regardless of whether I have turned off all applications. It also comes after a restart but then usually only for about 5 seconds.
I recently flashed the cache but that did not change the behavior.
Android version 7.1.2.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,031
4,086
113
Welcome to Android Central! Which phone? Do you mean you wiped the cache partition? You don't flash the cache -- you flash firmware to the phone (i.e., the system software).
Does the ringing sound like the default ringtone? Does it go away if you turn off NFC?
KHaze0420
