I've have a Huawei phone and need some help with iLauncher. How can I get it set as a default?
  • Start date Start date
A
AC Question
I've hot a huawei phone and need some help with ilauncher.
I have got a Huawei phone an have just installed ilauncher. I would like to know how u set it as default because each time I press home it goes back to the huawei home screen.
Re: I've hot a huawei phone and need some help with ilauncher.
Welcome to Android Central! Go to Settings>Apps>All, select the Huawei launcher (I'm not sure what it's called, but it should be fairly obvious in the list), and Clear Defaults. Now tap the Home button again, and it should ask you which launcher you want to use. Select iLauncher, and tap Always.
heidigodofwar
