Jager, SetCPU and Battery Life
AllGood
227
I've noticed a lot better battery life after installing Jager and using SetCPU to setup profiles.
Anyone else having success with this as well?
I've noticed a dramatic increase in battery life just using Jager. I'm not even adjusting the CPU.
And I even think that I might be using my phone more now than ever since installing the Roms.
What are some of the profiles you have set up?
I have mine set for when it gets to X battery percentage drop CPU down, when the battery gets to Y drop it lower and when it gets to Z drop it lower. Also set it to when the screen is off drop it down to like 386mhz
I think I read that setcpu doesn't work with the undervolt kernal or something like that.
i've had no issues with it. the widget doesn't update right nut i've had that issue with the droid as well
pcjordanellis
