Jellybean battery life?
funkylogik
9,631
111
this is my 1st full (well down to 5%) discharge since JB and it doesnt look great tbh
i know im not a normal user but compared to other days like this when the phones in constant use, this seems bad.
wish id done a "before" shot...
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
oops
58 percent of however long the phone was running mate lol :) (me bad at maths) :)
heres apps
everything looks normal percentage-wise though...
:confused:
I don't know, Funky - that all looks perfectly reasonable. You had the screen on almost the whole time. I don't know what your screen brightness setting was, but that would be the only thing that you could do to stretch your time out - I mean, you had WiFi on and were using the phone pretty much the whole time.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
yeah between 10-5% as the evening progressed mate and i wasnt connected to wifi, just had it on coz google Now likes it on lol.
i usualy get a bit longer with hard use like this.
ive constantly got a decent 3g (hsdpa/hspa+) connection so i duno if having wifi on in background makes a diff'?
(i dont have home wifi)
If I'm not mistaken wifi constantly looks for hot spots in the background when it's on and not connected. Next time you run your battery down touch the screen tab in battery usage tab, I'd like to see how long your screen was on.
Sent from my SCH-I535 using Android Central Forums
will do when im charged again mate. te battery actualy lasted well when i slept though and wifi only used .1% so it doesnt seem to be that....
from memory though, the screen was on most of the time, it was a heavy use discharge. maybe im imagining it but unless im streaming, i usualy get a bit longer when im sat online for hours (dont have home broadband).
i should really have recorded a test before JB to be sure.
everything does look prety normal percentage-wise...
yeah, think its just placaebo effect mate.
youre right.. also i was messin around with stuff more and maybe posting more as id just got JB
cheers :)
tonight with same heavy use although ive been playin around with homescreen
suppose its fair enough.
id do a test of the phone sleeping but i dont sleep for long enough :)
wow this is bit worse (actualy its not far off) although ive uploaded pics to fb and messed around with homescreen a bit
next full charge ill try wifi off just incase....
next time GPS...
Me too, you need to turn off all of Google's location reporting and the cause of the biggest drain is Samsung Push. I disabled it and now enjoy normal battery life. If you use the Samsung app it will enable it again but who needs that app anyhow. My wife still has ICS and after 1 day 12 hours she still had 73 percent battery after lite use. Tell people about Samsung Push as the battery life is really annoying everyone.
tota
