juice defender causing loss odf data connection
waterfrontmgmt
55
juice defender was making my charge lose its data connection in and out of wifi. uninstalled and now it stays connected. not losing 4g/3g any longer.
It seems to work on the Gingerbread leaks. I have been running for the last month or so and it was great. I switched back to EE4 due to the static issue while on a call and juice did not work well at all. I am on EP3 right now and it seems to be working just fine. Static is hit and miss though...
+1 on the uninstall. Ironically, my battery life is better and no longer do I have random resets (about 1 time a day).
Tis a shame but... it is what it is. YMMV
I am using EP1.
Yeah i was getting an error about the data connection, I uninstalled it and no more issues.
I had JD on my DroidX, had great success with increasing battery life. I was hoping that HD on my Charge would let me squeeze a little more from the battery, but sadly I found the same thing, the data connection wouldn't turn on. I even tried the option included in JD to toggle the Mobile Data Connection, but no success. I ended up disabling the app and all is working well now. I hope JD developer can work around this issue in a future release.
Are you on EE4 or a GB leak? Froyo EE4 did not work for me but on Gingerbread, my 4g and 3g come back as expected with Juice Defender. I am on the EP3 debloated rom currently.
i don't have a whole of developer/rooting apps - so that could be why I've done alright...
Not really as the stock ROM causes the problem, using a ROM to GB would fix the problem, all info ad per the JD developer. Im stock as well as confirm the problem with stock.
Sent from my SCH-I510 using Tapatalk
Drensic
