Just got the seidio 3500 battery what battery monitor is the best to use?
I.R.R.V.
196
8
Every thread I have found says that the phone thinks it is still charging a OEM battery, has anyone found a monitor that will show the actual batteries capacity? thanks for the replies.
battery monitor widget from market is a popular choice. I use it and it allows you to switch it to the type of mAH battery you are using.
Been using the gauge battery widget u get top bar notification as well as a choice of 2home screen widgets (free) and 4 (paid) plus paid as the customized options
Battery Monitor Widget is my choice as well. You can change the capacity of the battery in the options.
I got the battery monitor widget, it seems to work good, my first day I was able to keep my phone unplugged for almost nine hours, That included about 20 minutes of angry birds, and two movies on the hbogo app. With my stock battery I couldn't last 5 hours with the phone sitting not being used...
Marabishi
