kenwood DNR935WBT System rebuilding error
guyrat7
Hi All,
I am new to this forum and I come with issues. :)
I recently came across an unwanted Kenwood DNR935DBT car stereo. Reading its specs show the unit supports apps. The error on this unit points to the Android OS it might be running.
First of all, does this unit run a android OS?
So the issue is:
the unit powers up with the 'system rebuilding' error. Reset does not work.
I read on the xda-developer forum the partition might have run out of space hence this error.
The solution they suggest is to delete partition contents and perform a factory restore with the firmware update.
If this runs Android, do you know any ways I clear the partition enough to let the system do what it needs to do?
The main issue would be to access the system when it powers up. I would also like to know how to get it identified as a device on the PC to perform whatever troubleshooting on this.
Thank you for the help!
Guy
