Keyboard problem. Please help.
Nuuq
357
Purchased SwiftKey, but htc Keyboard keeps coming back. Whatever I do, still, after a while, I end up with htc... What to do? Is there way to disable it?
Live long and prosper.
you must still have the htc keyboard as default.
open swiftkey and see if it prompts you to select it as the default keyboard. if it does not, disable it in settings > language and keyboard and enable it again. press on swiftkey to open the app and check if it prompts you to select it as default again. chose yes.
You can disable the HTC Keyboard in the apps section of the settings I believe. But opening Swiftkey should fix it. Make sure its your default.
I disabled it, but now I only can do voice thingie... Don't get it...
Dejesus54
