Kia Sportage / Samsung Note 2 [Kia-Ipod-Cable]
I don't know if this will help but it syncs with my hyundai sonata's bluetooth for music and phone with no issues.
It's a Phone, it's a Tablet, It's a Phablet
thanks for the info. yes i did use and stream through bluetooth and it was pretty good i just wasnt sure if through the cable the sound is better and it would be charging the phone as well.
Well if you have a 3.5mm male to male cable you should be able to plug it into your phone's headphone jack. My car has the port but I never used it. I have used the USB and flash drive it works great
thanks. i will try that option as well. whats the cheapest best car charger to get for the n2? i figure maybe i will use a car charger and the aux cable? is the best setup?
thanks
thanks
As far as cheapest charger I am not sure maybe another member has some advice. As members start reviewing the Ibolt car dock I may be interested in buying. It comes with a charger and audio cable (I believe) and you can use it with a case on the phone.
I am having the same issue. The sound is much better with the cord & you can only use the controls on the steering wheel with the cord when changing the song on your phone. I am not happy at all! I miss my Iphone! Next upgrade I am going back!
