Latest update for Sprint's LG G2 improves LTE and HD audio. Build ZVE.
Does anyone know any specifics on what specifically improves with LTE in this update? I know that there was an issue with the BSRtimer set to 3000 and there is that tweak that allows you to change that to 3, which many have argued was the intended setting. Does this update do any more than fix that issue or for those of us that already made that tweak, can we expect even more?
I noticed the notification banner is transparent now. If you touch it turns gray
I still don't have the update, can anyone who has it confirm if that BSRTimer value is changed?
Although I changed my bsrtimer setting to 3 before the update, after the update I checked it and it was 3.
It might be worth noting I did an ##scrtn# reset a few months ago and it reset my bsr timer to 1 instead of the 3. I just left it as is lol. Still waiting on the update here though, but if it changes my timer I'll be sure to let you guys know.
Just got the update, before update my BSRTimer was 3000. after the update my BSRTimer is 3000. So, they didn't change that. Oh well, not sure what else they supposedly change to make LTE better, but that was not it...
I just finished the update and my bsr is still at 1 where my previous ##scrtn# reset set it. Everything in the LTE settings looks exactly the same. So I'm also curious as to what was changed.
EDIT: I even updated the profile after the update and it doesn't show any changes.
Could be a placebo effect, but it seems like my LTE is definitely better.
Posted from my LG G2
Got the update earlier this week. Thus far really haven't noticed any differences. I'm in the metro Dallas area and LTE still drops occasionally
Yeah...this to me was just a 'meh'. Okay... But yeah, I'm happy we'll be getting Lollipop 5.0 for sure.
kiki2025
