Launcher Pro Froyo issue
EvoUserXXX
52
My Launcher Pro will not stay on after the update. I set it as default and the second I press the home button it goes back to sense. Anyone else have this problem?
yep had the same issue with the .3 update.
I uninstalled home switcher(not sure if I needed too).
Went into settings/applications/ ended HTC
When I hit the home key I once again was given choice of sense or launcherPro. Picker launcherPro set as default
reinstalled home switcher
What do you mean by "ended HTC"...... HTC what ?
No problems here with Launcher Pro after 2.2 and enabling Pro Plus today.
You'll like Pro Plus. His bookmark widget is nice, and his calender/agenda widget just came out. both are top notch.
I meant to put I enabled it earlier today. It was enabled up until the update on Friday and I had forgotten. Top notch work, IMO.
menu/settings/applications/all/ HTC Sense
I appreciate the help Lorak, I tried it, it didn't work. After I stopped HTC sense, and it reloaded, I pressed home and still no option for Launcher Pro.
Any other ideas?
Yep one other thing to try (sounds goofy) but the problem might be qik.
So open your app dwarer, long press qik and drag it to trash can (can't actualy delete it) but it might get rid of the updates done to qik.
Then follow my steps above and see if it works.
Qik preventing homescreens default/switch has been seen on xda forums.
Dam, that didn't work either :/ .... I guess I'll have to wait for a update to see if it works eventually. I appreciate the help Lorak
Umm, when your at the HTC sense to stop it. Have you cleared defaults from there also?
I should have added that to my list too in the beginning also.
Wow thanks bro, that was it lol. I appreciate the help man!!!!! :) I am really enjoying Froyo like everyone else here :cool:
P.S. I dunno if you want to answer another quick question. I have tried using kongregate.com and I don't know how to make the game take the Full Screen. I was under the impression that you just hold the screen, but it doesn't do anything. I have had success with flash in video websites like justin.tv tho :)
umm just tried assembler (first game) when I move phone to landscape it goes to full screen automatically.
if your talking about getting rid of the text at the bottom, hit the back button, and then there is a window buttong underneith the red banner.
Sorry, not much help I guess
kostopge
