Launcher Pro Help
EvoUserXXX
52
I just started using Launcher Pro and liking it. But everytime I press home(so use to pressing it from using sense the last 2months) it asks to choose between sense and launcher pro. Is there anyway I can choose ONE and then go somewhere else to change it if I need to? I would love to just try using launcher pro for a while but be able to switch to sense If I need to. I am scared to set a default as I wouldn't know how to change back to sense.
P.S. where do some of you guys get these skins/themes for launcher pro? I can't find them in the market. What do I type in the search engine?
Thanks for the help :D Love the EVO !!!
Set it as default, if you ever need/want to change it, goto Settings-Applications-Manage Applications find Launcher Pro and select Clear Defaults
download an app called home switcher... it allows you to set defaults or just switch for a quick sec.
thanks for the input guys, you really helped :)
Now I was just wondering how can I search in the market for themes or skins for this?
And how do you guys get all those widgets on it ?
IndyJones1023
