Launcher pro plus disappear?
ghostyroasty
67
Did launcher pro plus just disappear from the market? Went to install it, and didn't see it anymore in the market.
Sent from my PC36100 using Tapatalk
Are you referring to LauncherPro or LauncherPro Plus? LauncherPro is in the market but LauncherPro Plus isn't. You need to donate to the developer in order to get the key to unlock the Plus features
in the dev's country, you arent aloud to put paid apps in the marketplace, so he made a work-around where you "donated" $2.99 to him and he gives you the key to unlock the extra features that are found in launcher pro plus. if you have launcher pro already then press menu>preferences>buy launcher pro plus at the bottom
I already purchased it, but I thought I did it via the Market.. I have to search my e-mails now! Thanks
You can open the launcher pro plus login screen an select lost password. They will send you a new email almost instantly
Sent from my ADR6300 using Tapatalk
John20
