Launcher pro plus keeps foreclosing after reboot
andonakis
226
4
18
It never fails. Every time I restart my phone launcher pro plus does a forceclose everytime. Why?
Nothing here? Any other programs running? Install then reinstall. You might have clicked something in the settings.
Make sure blur is cleared of widgets and shortcuts. Lp has given me no problems once I blanked the blur home screens.
I was having the same problem. Constant force closing and restarts and the phone was slooow to unlock. I uninstalled Launcher Pro and the Unlocker then reinstalled both. Haven't had any problems since.
I agree that the answer may lie in uninstalling LPP and then re-installing it. Had the same problems after the Froyo update and this solved it. Also, from time to time, LPP gets fussy and an uninstall and re-install usually takes care of it.
I had to give up on LLP because I has all the problems listed, FC, reboot and lock up with LLP installed.
As a final test give this a try, I was having issues with FC until I switched this feature off. In launcher pro settings:
Menu>preferences>Behavior>Make sure "Enable Auto Rotation" is unchecked, Reboot.
This solved my FC issues, have not had any FC issues since. For whatever reason LP does not work well with this feature enabled.
I stopped using LPP because of FC's. Switched to Go Launcher. Free and just as functional.
I've been having some problems with LPP lately ... previously, it was working fine for long periods. Now, though, it will give me broken screens, missing wallpaper, frozen screens, and the need for a force close, off/on or battery pull. Seriously considering removing it for a while. Not sure why it's become so unstable. Oh well.
Check out ADW EX at https://market.android.com/details?id=org.adwfreak.launcher&feature=search_result
ss-0-320-480-160-0-47f9c2908776aedda8582b856188ba64e674113e
ss-1-320-480-160-0-82616576e6b3db5afefadc926b4e59438bce59c4
toolman61
